802.1x and ATA
hello Team,
I am trying to configure 802.1x on the 2560 switches. We have some ATAs connected. I configured the MAB on the switch and configured the windows IAS server with the ATA MAC as user/password. However; when i connect the ATA to the switch port it doesn't get the IP address. Is there a way to make this work? here's my switch port config.
interface FastEthernet0/29
switchport access vlan 17
switchport mode access
switchport voice vlan 3030
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape 10 0 0 0
priority-queue out
mls qos trust device cisco-phone
mls qos trust cos
auto qos voip cisco-phone
dot1x mac-auth-bypass
dot1x pae authenticator
dot1x port-control auto
dot1x timeout tx-period 10
dot1x timeout supp-timeout 10
dot1x reauthentication
dot1x guest-vlan 999
dot1x auth-fail vlan 999
dot1x auth-fail max-attempts 2
spanning-tree portfast
I appreciate your help.
thanks
Anand
owillins Fri, 08/07/2009 - 12:56
  • Silver, 250 points or more
Try to assign static IP address. You can verify which IP address was assigned to the Cisco ATA with the IVR menu.
The Dynamic Host Configuration Protocol (DHCP) server is enabled by default from version 2.x and later. When the DHCP field is set to 1, the Cisco ATA 186 contacts the DHCP server to get the IP address, subnet mask, and default route.
http://www.cisco.com/en/US/products/hw/gatecont/ps514/products_configuration_example09186a00800c3a50.shtml#task1
