Error message
Answered Question
I received some error
%SYS-5-EOBC_CHANNELREINIT:Ethernet out of band channel reinitialized (1)
can't find any information. Please help.
Correct Answer by jbrenesj about 7 years 7 months ago
Indicates that a non-fatal error has occurred. It will let you know when
the EOB
(Ethernet out of Band) TX queue of the internal ASIC was getting stuck.
When this condition
is detected, it reinitialize the ASIC without resetting the switch.
The message is an informational message meaning that the tx queue EOBC
was reset since the tx queue was filled up. The EOBC is a 100 meg half
duplex connection that the linecards use to communicate. Its normal if
occasionally this is reported as its just doing a self recovery. Various
traffic like reporting and NMS can cause this to happen. If its
continually happening in the 100s per day, then its possible that the
mistral asic might be malfunctioning, but if its not happening much,
then its nothing that will affect your switch operation.
Overall Rating: 5 (2 ratings)
Correct Answer
jbrenesj Mon, 08/03/2009 - 14:24
  • Silver, 250 points or more
the EOB
When this condition
