UC520-Upgrading to 7.0
Aug 3rd, 2009
Hello
I am trying to upgrade my UC to the 7.0.3 firmware I downloaded. I am using CCA 2.0 for this.
Maintenance-->Software upgrade
The issue I have is, the status goes to 99%, then back to 97%, progresses to 99% and rolls back to 97%. ( CUE reloading)
It has been doing this for almost an hour now. The total duration has been 1.5 hours already.
Any pointers please!
aapexisinc Mon, 08/03/2009 - 20:51
I saw this same behavior using CCA 2.0.1; the % complete would get to 99, then fall back to 97, even 95, and work its way backup to 99.  This occurred many times before it finally finished successfully.  I don't recall how long it took, but it was rather disconcerting.
psingaraju Tue, 08/04/2009 - 10:27
Hello Marcos,
I upgraded my CCA to 2.0.1 with the same result. All the steps show as successful, do you think its only cosmetic?
I reset my phones, and they came up with the newest firmware, it is true for CME and CUE.
Let me know what you think,
Prasanna
