Compression question for the SSL-C module on CSS
Aug 3rd, 2009
  • Bronze, 100 points or more
Does anybody know what the newline format file type the the SSL-C module supports? I have a .js file and if I set the newline format of the source file to windows the CSS displays/delivers the last portion of the file. The moment I change the newline format of the source file to UNIX the problem goes away.
Also, if I convert all the tabs in the file to spaces (while still using windows newlines), the problem goes away as well.
Can someone please provide some insight?
Gilles Dufour Tue, 08/04/2009 - 02:18
  • Cisco Employee,
Weird.
The newline format should have no impact.
This seems like a bug.
Have you tried the latest version ?
If yes, open a service request with the TAC for follow up.
Gilles.
jason.espino Thu, 08/13/2009 - 20:53
Hello Gilles,
It turned out to be a code related issue on the CSS. Upgrading the firmware resolved the issue.
Thanks you for your input though!
