Unity 4.1 > 7.0 - adschemasetup failure.
Aug 3rd, 2009
I am performing a Unity 4.1(1) to 7.0 migration with New Hardware. I have built the new server and have installed 4.1(1), imported the DiRT Restore and am running the 7.0 installation portion.
Running Permissions wizard indicated I need to run adschemasetup.exe
Running adschemasetup.exe results in the following error:
Event Type: Error
Event Source: Application Error
Event Category: (100)
Event ID: 1000
Date: 8/3/2009
Time: 8:09:11 PM
User: N/A
Computer: HQDC02
Description:
Faulting application ADSchemaSetup.exe, version 0.0.0.0, faulting module ADSchemaSetup.exe, version 0.0.0.0, fault address 0x00008fb5.
The Windows 2003 server is 32-bit and was confirmed by running winmsd.exe - the processor is x86
The Windows 2003 server is holding the Schema Master Role - verifed by running mmc, adding Schama Master snapin and verifying the Operations Master.
When running adschemasetup.exe, I am not prompted for the Exchange Directory Monitor Checkbox. I do see an adschemasetup.log file created but no ldiff.log or ldiff.err.
I tell ya - I have the worst luck with Unity Migration/Installs
r.stockton Mon, 08/03/2009 - 21:31
RESOLVED:
Following the advise of TAC, we used the fix for CSCsl48851:
With names changed to protect the unwitting:
Assume:
Domain = cr7.com
Schema Master = crybaby
fqdn = crybaby.cr7.com
I'm using the extracted DVD - not the actual DVD.
ldifde.exe -i -k -c "" "CN=Configuration,DC=cr7,DC=com" -s "crybaby" -f "C:\Downloads\CiscoUnity7.0.2-DVD1\Schema\LdifScripts\avdirmonex2k.ldf" -j "C:\UnityLogs"
Output from the cmd line was:
C:\>ldifde.exe -i -k -c "" "CN=Configuration,DC=cr7
Connecting to "crybaby"
Logging in as current user using SSPI
Importing directory from file "C:\Downloads\CiscoUnity7.0.2-DVD1\Schema\LdifScri
Loading entries.................................................................
70 entries modified successfully.
The command has completed successfully
C:\>
So...HTH anyone else. Now for the rest of this upgrade - which, I'm sure, will take another "dive".
hehe...it just did - perm wizard is now reporting 27 errors....nice!
gnight
