AP Migration in WCS: "Failure - Veryfying Radio role"
Answered Question
Aug 3rd, 2009
while trying to convert autonomous APs (AIR-AP1121G-E-K9) to LWAPP mode WCS always says "Failure - Veryfying Radio role". Does anybody know why this occurs? The migration analysis summary shows all criteria as green. Thanks.
Correct Answer by Lucien Avramov about 7 years 11 months ago
In the logs folder of wcs: /wcs/webnms/logs/ there should be a direction for migration and logs from the migration of that ap.
Would you mind posting it?
Overall Rating: 4 (2 ratings)
Lucien Avramov Tue, 08/04/2009 - 20:55
  • Red, 2250 points or more
You probably dont have both radios in root mode:
dot11Radio 0
station-role root
shut
dot11Radio 1
station-role non-root bridge
shut
You should have :
dot11Radio 0
station-role root
shut
dot11Radio 1
station-role root
shut
You may have to reboot the ap after that to get it to work
f.wossal Tue, 08/04/2009 - 23:41
Thanks for your fast answer.
The problem still occurs.
I only have one radio (dot11Radio0) which is shutdown and the station-role is root:
interface Dot11Radio0
no ip address
no ip route-cache
shutdown
encryption vlan 176 mode ciphers aes-ccm tkip
broadcast-key vlan 176 change 600 membership-termination capability-change
ssid (...)
mbssid
speed basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
rts threshold 2312
bridge-group 1
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
Correct Answer
Lucien Avramov Wed, 08/05/2009 - 09:09
f.wossal Thu, 08/06/2009 - 04:54
Hi, I found the problem. The WCS had problems establishing a telnet session to controller. I solved it, now it works. Thanks for your help.
