Packet capture strange issue !
Aug 3rd, 2009
Dear All ,
I have 2 routers connected over wimax link. I decided to capture packets between their WAN IPs. this is my configuration
access-list 114 per icmp host host echo
access-list 114 per icmp host host echo-reply
monitor capture buffer holdpackets
monitor capture buffer holdpackets filter access-list 114
monitor capture point ip cef icmp all both
monitor capture point associate icmp holdpackets
monitor capture point start icmp
Now when i try to ping from to, this is the following result
Sending 5, 100-byte ICMP Echos to, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 52/80/140 ms
R1#sh monitor capture buffer all parameters
Capture buffer holdpackets (linear buffer)
Buffer Size : 262144 bytes, Max Element Size : 68 bytes, Packets : 0
Allow-nth-pak : 0, Duration : 0 (seconds), Max packets : 0, pps : 0
Associated Capture Points:
Name : icmp, Status : Active
No match on access-list either
R1#sh access-lists 114
Extended IP access list 114
10 permit icmp host host echo
20 permit icmp host host echo-reply
When i ran debug ip packet 114, i can see the packets going out but why are they not being matched by acl and also not in capture buffer ?
Can someone guide me pls ?
