LMS- RME- Software management erros
Aug 3rd, 2009
Can some tell me how to resolve this?
I did retry the job, but it failed- the ios version has bugs and that is why i'm upgrading to the latest ios version, but for some reasons- some devices are giving me this error meassage.
SWIM1011: Destination file size on storage location and the source file size are different.
This may be because of a network problem or a bug on the device.
Check the Bug Toolkit application for any known issues on the running image version. If there are no issues, retry the task.
Post-load validation failed. Aborting further operations on the device.
Image Copy Operation Failed
Joe Clarke Mon, 08/03/2009 - 23:50
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The error means that the size of the image on the RME server is different than the size of the image now on the device's flash. This is bad. It will most likely mean the device will not come back up if rebooted.
This could point to a CISCO-FLASH-MIB bug, bad flash, a network problem which corrupted the transfer, or a bug with SWIM. If multiple devices are giving you this error, then bad flash is probably not likely.
When we see these errors, the problem is almost always a device bug (i.e. bug with the CISCO-FLASH-MIB).
The best way to rule out RME is to try to transfer the image manually from the RME server to the device. If the problem still occurs, try a different transfer protocol (e.g. SCP as opposed to TFTP).
If the manual upgrade succeeds, this leaves a problem with the FLASH-MIB or RME. Since, as I said, most reports of this point to a device problem, you might have to bite the bullet, and complete the upgrade manually on these devices.
