Unable to pull or transfer activities in Cisco Web/Email Agent Console
Aug 4th, 2009
Hi all.
I have installed a Cisco Interaction Manager 4.2(1) and have upgraded it to version 4.2(5a). There are 2 servers in this setup, the 1st one is to host the apps, DB, svr services, and the other 1 is the web server.
Currently, I encountered a problem whereby whenever I click Transfer button and select "Queue" or "User" from the list, the agent console and the poop-up dialog hung and I got to end the process from the task manager. This problem didn't happen when it was version 4.2(1) before I upgraded the system.
Anyone has encountered such similar issue? Would highly appreciate any help or advice to solve this issue.
Thanks & Regards,
Eric
irisrios Mon, 08/10/2009 - 10:43
  • Silver, 250 points or more
See “Note about permissions to pull and transfer activities” in the document Cisco Unified Web and E-Mail Interaction Manager Administration Console User's Guide (Release 4.2(5)):
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/cisco_interaction_manager/cim_42/user/guide/cisco_im425_cce_userguide_administration.pdf
eric.neoh Mon, 08/10/2009 - 17:56
Hi, irisrios.
I have found out the cause and it was the client jre version which has got some memory issues with the system. JRE 1.6u7 is working fine with it.
Anyway, thanks for the advice and comment.
Eric
