2048 bit Certificate for LMS 3.1
Answered Question
Aug 4th, 2009
has anyone experiences how to use a CA signed 2048bit Certificate for SSL in LMS 3.1.
Per default LMS uses a self signed 1024bit Certificate which is not secure enough for our Security policies.
Thanks a lot
Correct Answer by Joe Clarke about 7 years 5 months ago
I had assumed you already had one signed by a CA or local to your organization. If not, you can change the instances of 1024 to 2048 in NMSROOT/MDC/Apache/bin/ConfigSSL.pl and SignTool.pl to generate such a cert.
Overall Rating: 3 (3 ratings)
Joe Clarke Tue, 08/04/2009 - 08:33
Modulo 2048 certs should be fine. Anything above that will most certainly trigger failures.
rfuerdauer Thu, 08/06/2009 - 01:43
That's good, but how can i generate a 2048 cert ?
I've found not hints in SSLUtil.pl or Help.
Correct Answer
Joe Clarke Thu, 08/06/2009 - 08:32
