08-04-2009 07:08 AM - edited 07-03-2021 05:54 PM
Is there an example that somebody can give me to setup a guest wireless network that only has access to the internet through a vlan that does not use a wireless controller? I am looking for any suggestions.
Thank you
Solved! Go to Solution.
08-04-2009 08:35 AM
Here is an example using ACL's to create a guest network. This prevents internal users from accessing internal private addresses and allows them to the internet.
interface Vlan199
description Guest
ip address 10.97.199.1 255.255.255.0
ip access-group 199 in
ip helper-address 10.xx
access-list 199 permit eigrp any any
access-list 199 permit udp any any eq bootps
access-list 199 deny ip any 10.0.0.0 0.255.255.255
access-list 199 deny ip any 172.16.0.0 0.15.255.255
access-list 199 deny ip any 192.168.0.0 0.0.255.255
access-list 199 permit ip any any
08-04-2009 07:31 AM
We use VRF on our 6500's, combined with WiSM's (in the 6500's), to shunt guest network traffic straight out to the inTARwebs. The Guest network definition on the WiSM is a different VLAN than the private network.
08-04-2009 07:37 AM
I have a 1231 AP connected to a 2960 switch which is connected to a 2811 router. I am using RADIUS to authenicate the users on the AD controller. I do not have a 6500 switch
Thank you
08-04-2009 08:35 AM
interface Vlan199
description Guest
