CSM and Secodary Firewall
Answered Question
Aug 4th, 2009
Hi All
Is it possible to add the secondary firewall also into the CSM using the standby IP, if firewalls are configured in active/standby failover
Correct Answer by suschoud about 7 years 9 months ago
you should never need to.
csm should only manage active unit.
changes are not replicated from standby to active.
what is the point of keeping different configs in both boxes.
hTh
Sushil
Overall Rating: 5 (1 ratings)
Correct Answer
suschoud Tue, 08/04/2009 - 10:36
  • Gold, 750 points or more
hTh
Sushil
