is the port 8443 required in order to accessUnified Communications Manager
Aug 4th, 2009
I would like to just type the ip address/ccmadmin as I previously did, is there a way to not have to remember to type the https://ccmip:8443/ccmadmin
chadlincoln Tue, 08/04/2009 - 09:18
As long as it is UCM 5 or higher, you can just type the IP address with nothing else and get there. Just put in hit enter and you should get there. Version 4 made you use the https as well as the ccmadmin, but 5 and higher, just the IP will work.
Please rate if this helped.
