Agent Remote ACS SE 4.2 in Win2003 64bits
Aug 4th, 2009
I have a trouble:
The logs of my ACS SE say me Internal Error, my remote agent is installed in a Windows 2003 Enterprise 64 bits
The agent remote work very well in a Active Directory 20003 of 64 bits?
Overall Rating: 4 (1 ratings)
Jagdeep Gambhir Tue, 08/04/2009 - 08:18
  • Red, 2250 points or more
Remote agent is not supported on 64 bit operating system.
~JG
Do rate helpful posts
Robert.N.Barrett_2 Thu, 08/06/2009 - 12:28
  • Bronze, 100 points or more
You might want to try running it in Compatibility Mode, and set the mode to a 32-bit OS flavor. In explorer, right-click on the .exe, choose properties, click on compatibility, then select a 32-bit OS.
Even it works, this won't be a Cisco-supported configuration.
moditsec12 Wed, 08/26/2009 - 05:30
Hello All,
I am also having an issue with ACS for 64-bit Windows Vista. Can anyone please suggest whether there is CISCO ACS Server for 64-bit Windows Vista ?
Thanks & Regards
Moditsec
Jatin Katyal Wed, 08/26/2009 - 06:05
  • Cisco Employee,
Unfortunately, ACS and remote agent currently does not support 64-bit systems .This is an enhancement request to have ACS supported on 64-bit systems.
A fix will be forthcoming and is planned for the ACS 4.2.1 Release. This will be available in mid of oct.
JK
