QoS - Need help Please!
pmajumder
Level 3
Level 3
I have the following QoS config on my external router.
ip access-list extended Voice-Devices
remark Voicemail Servers
permit ip host X.X.X.47 any
permit ip any host X.X.X.47
class-map match-any COS1-EF
match access-group name Voice-Devices
class-map match-any VOICE
match ip dscp ef
match ip dscp af31
policy-map Mark-COS1
class COS1-EF
set ip dscp ef
policy-map EIC-QoS-WAN
class VOICE
priority percent 12
service-policy Mark-COS1
class class-default
fair-queue
random-detect dscp-based
shape average 10000000
int s1/0
service-policy output EIC-QoS-WAN
My problem is that the traffic from x.x.x.47 is not been marked. However, traffic coming in with the ef and af31 bit already set is being picked up.
Can anyone give me a hand with this?
Thank you,
Pradeep
2 Accepted Solutions
John Blakley
Pradeep,
"My problem is that the traffic from x.x.x.47 is not been marked."
Are you needing this traffic marked? If the devices aren't marking the packet, you may need to mark the packet manually on the incoming interface that the device is connected to.
HTH,
John
HTH, John *** Please rate all useful posts ***
chinkevi_2
you're marking traffic after policing.
i would suggest to try create another inbound service policy on your lan interface for marking traffic instead.
13 Replies 13
John Blakley
Pradeep,
HTH,
John
Hi John,
Thanks for replying. Yes i do want that traffic marked with the DSCP value of "ef". Shouldn't x.x.x.47 satisfy the match criteria for class "COS1-EF" and mark that traffic accordingly?
Pradeep
Hello Pradeep,
This is interesting. Can you see the counters on the ACL actually increasing?
Best regards,
Peter
Hi Peter,
Yes I do see it increasing. In fact I am also sending icmp packets from x.x.x.47 as a test.
XD0R02#sh access-list Voice-Devices
Extended IP access list Voice-Devices
10 permit ip host X.X.X.47 any (52 matches)
20 permit ip any host x.x.x.47
Pradeep
Hello Pradeep,
I have pasted your config in my testing topology in Dynamips and it was working perfectly for me. The pings sent from X.X.X.47 were remarked with DSCP EF.
Are you absolutely sure that no remarking is taking place in your network? Is there perhaps a switch between the router and your machine where you capture the packets? Note that Catalyst switches with certain QoS settings may not trust DSCP marking and may reset it to 0.
Try using the command show policy-map interface s1/0 and watch closely for lines similar to these:
Class-map: COS1-EF (match-any)
1 packets, 104 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: access-group name Voice-Devices
5 minute rate 0 bps
QoS Set
dscp ef
Packets marked 1
The last line should tell you if the marking is taking place. If yes and you still do not see the packets marked on your end device then there is probably some other device in your network remarking your packets.
Best regards,
Peter
Hi Peter,
I am doing the marking on the router itself, so even if the packet got marked somewhere between the x.x.x.47 device and the router, I am assuming the latter will remark it?
I did use the cmd sh policy-map int s1/0 but all counters showed zero incl Packets marked.
I hope it's not a bug in my IOS - IOS (tm) 3700 Software (C3745-IS-M), Version 12.3(22)
Let me wipe out the config and start again, just to make sure. I will post the result.
Pradeep
Edison Ortiz
match ip dscp ef
match ip dscp af31
___
Remove the access-group 'Voice-Devices' from the class-map - you already have it under class-map match-any COS1-EF .
When calling the policy under the interface, Class Voice gets called first and executes the ACL without the marking.
HTH,
__
Edison.
chinkevi_2
The fact alone that the marking takes place after policing should not be a problem (even if perhaps not the best practice in this particular case). After all, with two rate policer, the same is done. Moreover, as I indicated, I have tested the Pradeep's configuration exactly as posted her and it worked for me.
Best regards,
Peter
@Edison..Originally my config did not include the access-group 'Voice-Devices' in the VOICE class-map. I added it only when it did not work.
@Peter.. I tried removing and re-adding the config without any success. It seems that the nested service policy Mark-COS1 is never getting invoked.
@Chin & John.. Creating an inbound service policy on my LAN interface worked! Thank you!
Peter - I am puzzled since I thought my original config would work and it doesn't but clearly works in your case.
Even though my issue is resolved I would really like to understand why my original config did not work!!
Pradeep
i think it did not mark traffic because there was not enough bandwidth to make QoS kick in to police the traffic in the first place.
I don't think this is the case. I have already seen it in other discussions here that it is assumed that the entire service policy kicks in only if the Tx ring of the interface starts to overfill.
In my opinion, that is not correct. A service policy on an interface must be evaluated for every packet. Only the software queueing kicks in when the Tx ring of the interface starts to fill but a service policy itself must act upon every packet.
This document provides slightly more detail:
http://www.cisco.com/en/US/tech/tk543/tk757/technologies_tech_note09186a0080160fc1.shtml
Best regards,
Peter
ajaykumar2k1
Pradeep
Not sure u missed or not.
Do the marking policy applied to correct interface.
Ajay
