Wic card
Aug 4th, 2009
I have C3745-IPVOICE-M, Version 12.3(4) T4. I had a tech @ the remote installed a T1 card , how ever the card does not show on the config.
I did the command
Config t
#card type ?
E3
T3
# Controller?
T3 T3 controller
cisco steps Tue, 08/04/2009 - 09:23
Slot 0:
C3745 Mother board 2FE(TX)-3W Port adapter, 8 ports
Port adapter is analyzed
Port adapter insertion time 28w6d ago
EEPROM contents at hardware discovery:
PCB Serial Number : JAE075105AM
Processor type : 69
Top Assy. Part Number : 800-15934-03
Board Revision : B0
Fab Part Number : 28-4672-04
Deviation Number : 65535-65535
Manufacturing Test Data : FF FF FF FF FF FF FF FF
RMA Number : 0-0-0-0
RMA History : 00
RMA Test History : 00
Field Diagnostics Data : FF FF FF FF FF FF FF FF
Hardware Revision : 2.0
Fab Version : 04
Chassis Serial Number : JMX0804L006
Product (FRU) Number : C3745-2FE
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF C1 8B 4A 41 45 30 37 35 31 30 35 41 4D 09
0x10: 69 40 02 F7 C0 46 03 20 00 3E 3E 03 42 42 30 85
0x20: 1C 12 40 04 80 FF FF FF FF C4 08 FF FF FF FF FF
0x30: FF FF FF 81 00 00 00 00 04 00 03 00 C5 08 FF FF
0x40: FF FF FF FF FF FF 41 02 00 02 04 C2 8B 4A 4D 58
0x50: 30 38 30 34 4C 30 30 36 FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 0:
FT1 PMC4351
Hardware Revision : 1.2
PCB Serial Number : FOC10522498
Part Number : 73-8346-05
Board Revision : A0
RMA History : 00
Deviation Number : 0-0
Product (FRU) Number : WIC-1DSU-T1-V2
Top Assy. Part Number : 800-22193-03
CLEI Code : IPUIAPRRAA
0x00: 04 FF 40 00 52 41 01 02 C1 8B 46 4F 43 31 30 35
0x10: 32 32 34 39 38 82 49 20 9A 05 42 41 30 03 00 81
0x20: 00 00 00 00 04 00 80 00 00 00 00 CB 94 57 49 43
Leo Laohoo Tue, 08/04/2009 - 14:18
There are no controller or controller-related commands, such as channel-group, to configure. With this WIC card, service-module commands are used. The syntax with regard to the framing, line-code, and so on remains the same. In this scenario a full T1 card with 24 timeslots is used.
Please check out the Sample Configuration for this WIC.
http://www.cisco.com/en/US/products/hw/modules/ps3129/products_tech_note09186a0080093d70.shtml#sample_config
or
http://www.cisco.com/en/US/products/hw/modules/ps3129/products_tech_note09186a00800b1501.shtml#sample_cfg
Hope this helps.
