Unity Connection License pooling
Aug 4th, 2009
i am installing 3 pairs of High Availability Connections 7.1.2a Servers and according to the docs at http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps5745/ps2237/product_data_sheet0900aecd806bfc37.html when networked together they should support license pooling however this does not appear to be the case. i read another post from Jeff L stating that License pooling was not supported or on the roadmap. Could someone clear up the confusion please
Many Thanks
Mazza
Overall Rating: 4.5 (2 ratings)
Jaime Valencia Tue, 08/04/2009 - 09:20
AFAIK we do not have License Pooling in CUC 7.X release, i believe it might be in the roadmap but not 100% sure.
Also, if Jeff says it's not supported, i would take his word on that
java
if this helps, please rate
Tana Franko Tue, 08/04/2009 - 16:56
java is right, license pooling is not available in Connection 7.x. Thanks for bringing it up. I've contacted the doc owners to let them know about the error so they can fix it.
