URL Filtering Questions
As possible Microsoft ISA server replacement next year, I would like to move URL filtering to the ASA systems if possible. Can anyone tell if using the ASA for this is a good alternative?
Here is what I would like.
1.) The ability to block certain URLs from being accessing by employees.
2.) The ability to track and report of employee Internet usage.
Overall Rating: 5 (2 ratings)
suschoud Tue, 08/04/2009 - 11:41
asa works in conjunction with websense or smartfilter for url filtering.
all http/https/ftp etc reqeusts are redirected to these servers wherein url filtering rules are applied.
if u do not have these boxes,u can also use inbulit asa's capability to use regex ( regular expression ) to block urls.
For ex. , blocking myspace :
ciscoasa(config)# sh run
: Saved
ASA Version 7.2(2)
hostname ciscoasa
regex block-website ".\myspace.\com"
class-map type regex match-any cm-block-website
match regex block-website
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
message-length maximum 512
policy-map type inspect http pm-block-website
match request header host regex class cm-block-website
drop-connection log
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
%ASA-5-415008: HTTP - matched request header host regex class
cm-block-website in policy-map pm-block-website, header matched - Dropping
connection from Inside: to outside:
%ASA-6-302014: Teardown TCP connection 2036 for outside: to
inside: duration 0:00:00 bytes 0 Flow closed by inspection
Here is a link that explains how to use MPF:
-- Using Modular Policy Framework:
asa has limited capabilities to track internet usage.u can use some 3rd party tool for that.
suschoud Tue, 08/04/2009 - 13:26
Commercial products that creates graphs and analyzes Syslog to generate stats could be:
- FireGen http://www.eventid.net/firegen/
- Try this one FWLOGSUM (Freeware).
It uses basicly PERL scripts and supports a wide range of Firewalls. You just need to install Perl in your Windows environment.
- Try Sawmill (Eval version)
- EIQ Networks Network Security Analyzer eiqnetworks.com
Hope that gives you some ideas what to try.
