Cisco 2600 implement ipsec passthrough
Aug 4th, 2009
Hello, at work we have :
internet--cisco2600--firewall(openbsd)--LAN
on our lan we have a ftp server, we have configured vpn ipsec on openbsd using ike(esp) to secure our ftp on internet.
Now, i want to configure my cisco to pass ipsec passthrough packets. Can you help me please?
Thank's
John Blakley Tue, 08/04/2009 - 11:25
  • Purple, 4500 points or more
Do you have any access-lists on the router? If not, it will pass everything through. If you have an acl on the outside interface on the router, you'll need to make sure that you allow:
esp
udp 500
HTH,
John
cisco24x7 Tue, 08/04/2009 - 13:05
  • Silver, 250 points or more
let say cisco 2600 public ip address is 1.1.1.1 and openBSD firewall external IP facing the cisco router is 192.168.1.1
and that the cisco router is connected to the OpenBSD firewall is 192.168.1.254. Here is how you do it:
interface f0/0
ip nat outside
ip address 1.1.1.1 255.255.255.252
ip access-group 100 in
interface f0/1
ip nat inside
ip address 192.168.1.254
access-list 100 permit udp any any eq 500 log
access-list 100 permit esp any any log
access-list 100 permit udp any any eq 4500 log
ip nat inside source static udp 192.168.1.1 500 interface f0/0 500
ip nat inside source static esp 192.168.1.1 interface f0/0
ip nat inside source static udp 192.168.1.1 4500 interface f0/0 4500
Basically anyone connect to the cisco 2600 will be forward to the OpenBSD firewall for VPN access. This works
for both remote access and L2L VPN.
Easy right?
