Ping from a Layer 2 switch
Aug 4th, 2009
Hello Everyone,
on a layer 2 switch cluster of 3560s without a management VLAN IP address should I be able to ping devices connected to the switch? Devices can ping each other but I can't get a ping response with I try to ping anything from the switch.
Thanks in advance. All replies rated
Overall Rating: 5 (2 ratings)
jfraasch Tue, 08/04/2009 - 11:08
Wouldn't think so. How would the device you are trying to ping know where to respond back to without an IP?
davy.timmermans Tue, 08/04/2009 - 11:11
  • Silver, 250 points or more
It's not possible to ping from the switch without an IP configured (management vlan). If an IP is configured on the switch, ip default-gateway is required in order to ping a device in another subnet than the management vlan.
3560 has L3 capabilities but you can use the switch as L2 switch (no ip routing).
