EIGRP MD5
Answered Question
When our EIGRP routing was first setup the installers didn't secure it. We now have 25 routers, and it is way past time to secure it. I have read and understand how to enable and have done so on there networks with OSPF, but not once the network is using it.
How can I set this up without taking the network down?
Any thoughts.
Thank You
Correct Answer by Jon Marshall about 7 years 11 months ago
Jeff
Once MD5 auth is enabled on all interfaces then changing the key can be done without any downtime.
But as Jerry notes this won't work when you actually configure it for the first time.
If no downtime is acceptable then one way around this is to configure a second EIGRP AS on each router. Because authentication uses the AS number a second AS would allow you to break the original AS while adding MD5 auth and the router will still have all the routes in the second temporary AS.
Once MD5 is enabled and working in the original AS then you can delete the second temporary AS.
Jon
Overall Rating: 5 (3 ratings)
Jerry Ye Tue, 08/04/2009 - 12:13
  • Cisco Employee,
Hi Jeff,
EIGRP authentication is a per interface configuration. It will affect the directly connected interfaces. When you enable authentication on two (2) adjacent interfaces (remote first then local), since EIGRP converge really fast, the neighbor adjacency will flop (depend on how fast you enter the commands on that interface).
HTH,
jerry
Correct Answer
Jon Marshall Tue, 08/04/2009 - 12:23
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jeff
Jon
Jon Marshall Tue, 08/04/2009 - 12:28
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Thanks Jerry.
Jerry Ye Tue, 08/04/2009 - 12:30
  • Cisco Employee,
Not EIGRP, you can have multiple process.
Single process for BGP.
HTH,
jerry
Jon Marshall Tue, 08/04/2009 - 12:34
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Jeff
No you don't need to redistribute between the 2. You just configure a second AS on each router with the same configuration as the first.
Jon
