Mixed login in Cisco Router
Answered Question
Aug 4th, 2009
Hi all:
I have configured Radius on all my network devices, but I need to enable mixed login (Radius and local) for only one of them (creating a local admin user)
Could someone help me?
Thanks!!
W.
Correct Answer by Jagdeep Gambhir about 7 years 9 months ago
Walter,
In that case you need to use local first,
aaa authentication login default group local RadiusServers
~JG
Do rate helpful posts
Overall Rating: 5 (1 ratings)
Jagdeep Gambhir Tue, 08/04/2009 - 13:01
  • Red, 2250 points or more
Here are the command
Router(config)# username [username] password [password]
radius-server host [ip]
radius-server key [key]
aaa new-model
aaa authentication login default group radius local
Request will first go to radius and if it is down then it will let you in using local credential.
~JG
walter.perera Tue, 08/04/2009 - 13:11
Hi JG
Thanks for your answer.
We have quite similar config:
aaa new-model
aaa group server radius RadiusServers
server [IP] auth-port [PORT1] acct-port [PORT2]
aaa authentication login default group RadiusServers local
aaa authentication enable default group RadiusServers enable
aaa session-id common
and when Radius is down, it works, but we want to create a local user on one of the routers and let them login not using Radius (the rest of the users will continue using Radius)
Hope it is clear.
W.
Correct Answer
Jagdeep Gambhir Tue, 08/04/2009 - 13:21
Walter,
~JG
walter.perera Wed, 08/05/2009 - 03:48
Hi JG:
Thanks for your post. It works!
Just a small change:
aaa authentication login default local group [RadiusServers]
