IP Phone Services
Answered Question
I have three Call Manager clusters. I was wondering if it's possible to add the Call Manager phone directory as a IP Phone service onto a phone outside of it's cluster?Possible or Thoughts?
Correct Answer by Jaime Valencia about 7 years 5 months ago
You can either add a custom directory which will provide more options or have them as services (just like 7.1(2) has them
Of course this means you'll need to custom develop the applications and if the clusters are not the same OS (Linux/Windows) you'll have to manipulate them as the scripts are not the same
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Tue, 08/04/2009 - 17:54
java
