ip communicator issue w/ Vista
Answered Question
Aug 4th, 2009
i have an issue with my ip com V2.1,
those are the caracteristics of my laptop:
HP Pavilion DV2735LA
Vista 64
speakers (Conexant High Definition Audio)
sound card interface SPDIF (Conexant High Definition Audio)
I tried w/ ip comm 7(0)2 and i had the same issue.
I was researching and i found that it could be a bug.
I attach the error and the bug.
What version i have to use to make it work?
Regards.
Correct Answer by Nicholas Matthews about 7 years 9 months ago
Hi Amanda,
This is likely because Vista 64 bit is not supported.
You can look at this table here to find out what should work with IP Communicator 7.0:
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cipc/7_0/english/release/notes/CIPC70_RN.html#wp49960
hth,
nick
Overall Rating: 5 (1 ratings)
