WAAS - Bandwidth Management support?
Sorry, I had a problem with the web. My comment was:
I know that other products such as Juniper's WXC supports Bandwidth Management. Does Cisco WAAS support it too?
Bandwidth Management means:
- Guarantee a minimum bandwidth for your most critical applications.
- Set maximum bandwidths to limit (or drop) low-priority traffic.
- Set priorities to determine how the “excess” bandwidth is allocated.
Thanks in advance.
José Luis
Zach Seils Fri, 08/07/2009 - 13:29
José,
The WAAS architecture relies on the underlying network infrastructure to manage the QoS for each type of traffic/application. WAAS provides the ability to mark/remark DSCP values in order to signal to the network infrastructure how traffic should be handled.
Zach
