Trunking issue with autonomous AP
Aug 4th, 2009
I was at a customers that wanted a new ssid configured on his 20 1252 AP's and to stand up a new one with the olds and new SSID on it. Added the vlans, trunked them down and configured the interfaces and SSID's on the existing AP's no biggie. The new AP(not really new been kicking around in a lab) is giving me some weird issues. I deleted the exisiting config from it and took one of the running configs fromm the others that are working, modified the name and ip and pasted it in. This should have worked just fine. However the trunk port on the 4507 will not come up. The radio's are up and so is the BVI, however I cannot ping to it since the trunk is down. I started looking at the config and the thing I notice is that the AP's are in vlan 2, and the native vlan is set for vlan 2 on all the working trunk ports on the switch. However the AP's do not have vlan 2 on them, and their native vlan is 1. This should not work! I always thought the native had to match on both sides?? In any case I am probably missing something stupid, I have been up since 4am it was a 4 hour drive to get here. Oh and I have to go back and make firewall changes at midnight. Here is the relavent configs please let me know if its something stupid I usually do a lot of controller based installs havnet done a autonomous one in years. Thanks!
Here is a port on the switch
interface GigabitEthernet3/9
description AP 1 - SMT
switchport access vlan 2
switchport trunk native vlan 2
switchport trunk allowed vlan 2,9,15
switchport mode trunk
end
Here is the AP hanging off that works fine
cstwap01#sh vlans
Virtual LAN ID: 1 (IEEE 802.1Q Encapsulation)
vLAN Trunk Interfaces: Dot11Radio0
Dot11Radio1
GigabitEthernet0
This is configured as native Vlan for the following interface(s) :
Dot11Radio0
Dot11Radio1
GigabitEthernet0
show run on the AP
dot11 mbssid
dot11 vlan-name VoIPVLan vlan 9
dot11 vlan-name Wireless-101-Legacy vlan 15
dot11 ssid 101
vlan 15
authentication open
mbssid guest-mode
dot11 ssid VoIPVLan
vlan 9
authentication open
mbssid guest-mod
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid 101
ssid VoIPVLan
interface Dot11Radio0.9
encapsulation dot1Q 9
no ip route-cache
bridge-group 9
bridge-group 9 subscriber-loop-control
bridge-group 9 block-unknown-source
no bridge-group 9 source-learning
no bridge-group 9 unicast-flooding
bridge-group 9 spanning-disabled
interface Dot11Radio0.15
encapsulation dot1Q 15
no ip route-cache
bridge-group 15
bridge-group 15 subscriber-loop-control
bridge-group 15 block-unknown-source
no bridge-group 15 source-learning
no bridge-group 15 unicast-flooding
bridge-group 15 spanning-disabled
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
no bridge-group 1 source-learning
bridge-group 1 spanning-disabled
interface GigabitEthernet0.9
no ip route-cache
bridge-group 9
interface GigabitEthernet0.15
no ip route-cache
bridge-group 15
interface BVI1
ip address 10.190.2.51 255.255.255.0
no ip route-cache
ip default-gateway 10.190.2.1
Roman Rodichev Tue, 08/04/2009 - 19:33
  • Gold, 750 points or more
Hello Mike,
actually, native VLAN doesn't have to match on two sides of a trunk, in fact it's quite common with autonomous APs. Your BVI1 is usually tied to a native VLAN 1, but switch port native VLAN is usually configured for whatever VLAN you want AP's management IP to belong to, in your case VLAN 2.
When you connect two catalyst switches together with a trunk that has different native VLAN configured on two sides, you will keep getting logging messages warning you about it. It's not recommended, but some scenarios require such setup.
Something else is wrong, maybe a physical issue. When you say the trunk is down, do you mean the interface is down ? Can you paste config of bad switch port and bad AP?
Roman
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
