ZBFW "SIP Protocol Violations"
Endorsed Question
We have a site that is experiencing SIP Protocol Violation errors from the Zone-Based Firewall Policy configuration. Here is a little bit of info about the site design and some logs desplaying this particular error:
-remote site connected to central site via a vpn tunnel
-both routers(1841 & 2801) have a basic ZBFW config that is specifying SIP traffic as being permissible from one site to the other
-phones are Grandstream and SIP server is a Trixbox(we use CME and Cisco IP Phones for all of our builds; these two sites are for a small company that made a purely cost-driven decision about equipment)
-SIP server is 192.168.14.10 at central site
-Grandstream phones are 172.20.14.0/24 at remote site
The following are logged sessions from the router at the remote site(where phones are attempting to establish communication across vpn tunnel with SIP server):
1)phone to server SIP traffic
a)Aug 4 11:16:19 207.201.235.14 67: NSA_remote: 000063: Aug 4 15:16:19.055 UTC: %FW-6-SESS_AUDIT_TRAIL_START: (target:class)-(InsideToCentral:outbound_sip_class):Start sip session: initiator (172.20.14.30:5060) -- responder (192.168.14.10:5060)
b)Aug 4 11:16:19 207.201.235.14 68: NSA_remote: 000064: Aug 4 15:16:19.135 UTC: %AIC-4-SIP_PROTOCOL_VIOLATION: SIP protocol violation (Forbidden header field found) - dropping udp session 192.168.14.10:5060 172.20.14.30:5060 on zone-pair InsideToCentral class outbound_sip_class
c)Aug 4 11:16:19 207.201.235.14 69: NSA_remote: 000065: Aug 4 15:16:19.135 UTC: %FW-6-SESS_AUDIT_TRAIL: (target:class)-(InsideToCentral:outbound_sip_class):Stop sip session: initiator (172.20.14.30:5060) sent 585 bytes -- responder (192.168.14.10:5060) sent 0 bytes
2)server to phone SIP traffic:
a)Aug 4 11:16:19 207.201.235.14 70: NSA_remote: 000066: Aug 4 15:16:19.139 UTC: %FW-6-SESS_AUDIT_TRAIL_START: (target:class)-(CentralToInside:inbound_sip_class):Start sip session: initiator (192.168.14.10:5060) -- responder (172.20.14.30:5060)
b)Aug 4 11:16:19 207.201.235.14 71: NSA_remote: 000067: Aug 4 15:16:19.143 UTC: %AIC-4-SIP_PROTOCOL_VIOLATION: SIP protocol violation (Invalid Dialog) - dropping udp session 192.168.14.10:5060 172.20.14.30:5060 on zone-pair CentralToInside class inbound_sip_class
c)Aug 4 11:16:20 207.201.235.14 72: NSA_remote: 000068: Aug 4 15:16:19.143 UTC: %FW-6-SESS_AUDIT_TRAIL: (target:class)-(CentralToInside:inbound_sip_class):Stop sip session: initiator (192.168.14.10:5060) sent 0 bytes -- responder (172.20.14.30:5060) sent 0 bytes
For each attempt, outbound sip traffic(from phone to server) flags the "Forbidden header field found" violation. And inbound sip traffic(server to phone) flags the "Invalid Dialog" traffic.
I have posted this over in the IP Telephony section of Netpro as well.
Any help would be greatly appreciated. Thanks for your time.
Endorsed by Julio Carvajal
sadsiddi about 7 years 7 months ago
In the pcap, i see all REGISTER messages. I dont see 100 Trying messages. i believe the pcap was captured when firewall is in place which dropped the non-RFC compliant 100 Trying messages. From the debugs i infer that, the 100 Trying message had "CONTACT" and "REPLY-TO" headers which as per RFC 3261 should not be present. You need to check your SIP gateway why is that sending non-RFC 100 messages. On IOS Firewall, you can skip this strict RFC-3261 check by having the follwoing config.
Class-map type inspect sip class-sip
Match protocol-violation
Policy-map type inspect sip policy-sip
Class type inspect sip class-sip
Allow
Log
class-map type inspect match-any cmap
match protocol sip
policy-map type inspect pmap
class type inspect cmap
inspect
service-policy sip policy-sip
Hope this helps.
Overall Rating: 5 (1 ratings)
sadsiddi Tue, 08/04/2009 - 19:09
What IOS version are you using?.Can you get the output "debug policy-firewall detailed" and "debug policy-firewall prot sip"?
sadsiddi Tue, 08/04/2009 - 19:55
Pls post the debugs and packet capture as well, both taken at the same time.
sadsiddi,
Thanks so much for your help. I appologize it took me a little time to get back with you. I have the "debug policy-firewall protocol sip" output attached, as well as some brief packet-captures from around the same time. I'm going to set this up in a lab to gain more information shortly.
Thanks again for your assistance, and please feel free to make any recommendations.
sadsiddi Tue, 08/11/2009 - 09:41
Allow
Log
match protocol sip
inspect
Hope this helps.
sadsiddi,
Thanks so much for your response. We are investigating the strange non-RFC headers you mentioned in your post. We did make adjustments to our current firewall config and are now able to make calls from the phones. Thank you very much for your assistance.
I actually ran a few more debugs and tried to get concurrent packet captures. I am posting some output from our most recent testing after making the modifications to our ZBFW config.
I am still seeing quite a few dropped packets, but again I want to stress that right now we are very happy that we're just able to make calls.
We appreciate all of your help, and please feel free to make any recommendations.
ROBERTO TACCON Fri, 09/11/2009 - 04:58
I've the same problem but how I can configure to skip the SIP check on the "
policy-map type inspect policy-trust-untrust" ?
When I try to attach the child policy the IOS tell me the following:
CISCO2811-VR-IT(config)#policy-map type inspect policy-trust-untrust
CISCO2811-VR-IT(config-pmap)#class type inspect class-trust-untrust
CISCO2811-VR-IT(config-pmap-c)#service-policy sip policy-sip
Deep packet inspection action of the configured type not applicable to protocol "ftp" in class "class-trust-untrust". Please remove the protocol and try.
Unable to attach child policy
Please can you help me in a configuration like the following:
class-map type inspect sip match-any class-sip
description ** SIP PROTOCOL
match protocol-violation
class-map type inspect match-any class-untrust-trust
description ** INTERNET TO INSIDE
match protocol telnet
match protocol ssh
match protocol icmp
class-map type inspect match-any class-trust-untrust
description ** INSIDE TO INTERNET
match protocol sip
match protocol ftp
match protocol ftps
match protocol sip-tls
match protocol pptp
match protocol tftp
match protocol stun
match protocol tcp
match protocol udp
match protocol icmp
policy-map type inspect policy-untrust-trust
class type inspect class-untrust-trust
inspect
class class-default
drop log
inspect
class class-default
drop log
policy-map type inspect sip policy-sip
class type inspect sip class-sip
allow
log
zone security trust
zone security untrust
zone-pair security trust-untrust source trust destination untrust
service-policy type inspect policy-trust-untrust
zone-pair security untrust-trust source untrust destination trust
service-policy type inspect policy-untrust-trust
ROBERTO TACCON Fri, 09/11/2009 - 05:38
Hi;
please can you check the following configuration.
I've try to configure to skip the SIP protocol violation but the IOS drop:
class-map type inspect match-any class-sip-trust-untrust
match protocol sip
match protocol ssh
match protocol icmp
match protocol sip
match protocol ftp
match protocol ftps
match protocol pptp
match protocol tftp
match protocol stun
match protocol tcp
match protocol udp
match protocol icmp
inspect
class class-default
drop log
allow
log
class type inspect class-sip-trust-untrust
inspect
inspect
class class-default
drop log
zone security trust
CISCO2811-VR-IT#
015590: Sep 11 15:32:22.932 CET: CCE: CBAC SIP: Multiple VIA Headers found
015591: Sep 11 15:32:22.932 CET: CCE: sip_fetch_record_route_addr
015592: Sep 11 15:32:22.932 CET: CCE: sip_fetch_sip_URI
015593: Sep 11 15:32:22.932 CET: CCE: sip_fetch_sip_URI
015594: Sep 11 15:32:22.932 CET: CCE: sip_fetch_to_addr
015595: Sep 11 15:32:22.932 CET: CCE: sip_fetch_sip_URI
015596: Sep 11 15:32:22.932 CET: CCE: sip_fetch_from_addr
015597: Sep 11 15:32:22.932 CET: CCE: sip_fetch_sip_URI
015598: Sep 11 15:32:22.932 CET: CCE: sip_fetch_cseq
015599: Sep 11 15:32:22.932 CET: CCE: sip_fetch_seq_no
015600: Sep 11 15:32:22.932 CET: CCE: SIP: Err: protocol-voilation checking: Message 180 is not permitted in state Transaction Init
015601: Sep 11 15:32:22.932 CET: FIREWALL sis 4A6100C0: *** protocol error found ***
015602: Sep 11 15:32:22.932 CET: %AIC-4-SIP_PROTOCOL_VIOLATION: SIP protocol violation (Invalid Transaction) - dropping udp session 192.168.1.55:58140 83.211.227.21:5060 on zone-pair trust-untrust class class-sip-trust-untrust
015603: Sep 11 15:32:22.932 CET: FIREWALL: Pregen without any dialog
015604: Sep 11 15:32:22.936 CET: FIREWALL: Pregen without any dialog
015605: Sep 11 15:32:22.936 CET: FIREWALL sis 4A6100C0: Sis extension deleted
015606: Sep 11 15:32:22.936 CET: CCE: I2R = 1, source = 192.168.1.55:58140, dest = 83.211.227.21:5060, state_object = 0x0, data_len = 4
015607: Sep 11 15:32:22.936 CET: CCE: SIP: Err: Response Invalid
015608: Sep 11 15:32:22.936 CET: FIREWALL sis 4A6100C0: *** protocol error found ***
015609: Sep 11 15:32:22.936 CET: FIREWALL sis 4A6100C0: Sis extension deleted
015653: Sep 11 15:43:22.948 CET: %AIC-4-SIP_PROTOCOL_VIOLATION: SIP protocol violation (Invalid Transaction) - dropping udp session 192.168.1.55:58140 83.211.227.21:5060 on zone-pair trust-untrust class class-sip-trust-untrust
015654: Sep 11 15:44:22.952 CET: %AIC-4-SIP_PROTOCOL_VIOLATION: SIP protocol violation (Invalid Transaction) - dropping udp session 192.168.1.55:58140 83.211.227.21:5060 on zone-pair trust-untrust class class-sip-trust-untrust
ROBERTO TACCON Fri, 09/18/2009 - 01:12
Yes the problems with SIP phones persist !
1)- How can I disable the SIP protocol inspection (but leave SIP ALG active) ?
2)- FYI: WITH A cisco PIX/ASA version 7.x the IP SIP phone works perfectly/correctly !
3) how I can configure the IOS to log (by syslog) every sessions created/dopped/... by the IOS zone firewall ?
I've configured the following but the firewall ONLY log the dropped packets.
ip inspect log drop-pkt
ip inspect audit-trail
4) "Please can you confirm me that the IOS ZONE based firewall is configured correctly: the inside lan need to connect to an external SIP gateway.
I've tried to configure the firewall to "bypass" the SIP check (but still use the SIP ALG) but still not working.
match protocol sip
match protocol ssh
match protocol icmp
match protocol sip
match protocol ftp
match protocol ftps
match protocol pptp
match protocol tftp
match protocol stun
match protocol tcp
match protocol udp
match protocol icmp
inspect
class class-default
drop log
allow
log
inspect
inspect
class class-default
drop log
zone security trust
interface FastEthernet0/0
description ** INSIDE LAN
ip address 192.168.1.199 255.255.255.0
ip nat inside
ip virtual-reassembly
zone-member security trust
ip tcp adjust-mss 1452
duplex auto
speed auto
interface ATM0/0/0
description *** connected to INTERNET
bandwidth 24000
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip flow ingress
ip nat outside
load-interval 30
no atm ilmi-keepalive
pvc tiscali 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface Dialer0
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
zone-member security untrust
encapsulation ppp
load-interval 30
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname [email protected]
ppp chap password xxxxxxxxxxxxxx
ppp ipcp dns request
CISCO2811-VR-IT#sh ver
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9-M), Version 12.4(24)T, RELEASE SOFTWARE (fc1)
Do you need anything else (the debug packets) ?
THANKS for your help!
RosInterBank Tue, 07/24/2012 - 06:07
Is this problem solved?
I'm running 891 with adv. ip services and have same problem. IOS from c890-universalk9-mz.152-2.T
Yes, sip are broken on some sip-gateways, programmers of remote gateways know about it and not going to do anything with it, thats not a question, and we have to live with it. Question is how to turn off "%AIC-4-SIP_PROTOCOL_VIOLATION: SIP protocol violation (Invalid Transaction) -  dropping udp session". Looks like allowing protocol-violation not working or i'm doing something wrong. Here is config:
  allow
  log
class-map type inspect match-any sip
match protocol sip
policy-map type inspect voice-internet
  inspect
Log:
CCE: SIP: Err: protocol-voilation checking: Message 200 is not permitted in state Transaction Init
FIREWALL sis 89443BA0: *** protocol error found ***
%AIC-4-SIP_PROTOCOL_VIOLATION: SIP protocol violation (Invalid Transaction) -  dropping udp session x.x.x.x:5060 y.y.y.y:5060 on zone-pair data-internet class sip
It migth be message 180, or whatever message.
"policy-map type inspect sip policy-sip" just not allowing, but it logging (3rd line in log).
Richard H. Shores Thu, 06/27/2013 - 02:00
Just to keep this thread going...the problem still exists with 15.2(4)M3. I had to downgrade to 15.1(4)M6 to fix the problem on a 7206VXR router.
Best regards
Utair Corporation Wed, 10/16/2013 - 03:20
Just stumbled upon AIC-4-SIP_PROTOCOL_VIOLATION in 15.2(4)M5
Any way for workaround? L7 inspection is needed for dynamic RTP pass.
Richard H. Shores Wed, 10/16/2013 - 04:06
To Utair Corporation:
Looks like the bug is in all 15.2M releases per
Bug CSCui66278 ZBF: SIP inspection drops legitimate packets as protocol violation
https://tools.cisco.com/bugsearch/bug/CSCui66278/?referring_site=ss
It is fixed in 15.3 and 15.4 IOS releases, which is only available for the latest Cisco router products. Check the bug info, as it has a workaround, but it may affect your L7 inspection.
As I posted above back in June 2013, the problem went away for me with 15.1(4)M6.
Hope this helps!
Best regards!
Utair Corporation Wed, 10/16/2013 - 20:56
They have added support for FTP EPRT and EPSV extensions in 15.2, wich were main reason for upgrade, so i don't want to rollback.
And i've tried workaround - doesnt work. Had to simply pass SIP and RTP.
Also, i've got same results on 15.3(2)T IOS on 2911 router.
SIP devices is all Cisco, VCS-Expressway on one side and Cisco E20 on another.
Richard H. Shores Thu, 10/17/2013 - 17:18
I would call TAC and get them involved. It sucks when there are new features introduced in IOS and there are bugs from the start.
Good luck to you!
Best regards!
