Translation Pattern Question
Aug 4th, 2009
Let' say a site supports both 7 and 10 digit dialing for local calls.
If you have two translations patterns:
9.321[2-9]xxxxxx (321 is the NPA)
Let's say you dial 9.321.543.1213
Which translation pattern would be used first? The 7 digit xlate or 10 digit xlate? The urgent pointer is enabled on both xlate patterns. Both would be matched!! Thanks!
Jaime Valencia Tue, 08/04/2009 - 18:00
In this case since they work like dial-peers you'll always end up using the 7 digit since it matches before
You would need to add a ! or a + at the end of the 7 digit so you can match 10 digits
if this helps, please rate
