08-04-2009 05:35 PM
I am using VPN3000 concentrator for VPN client users. ryt now auth is happening trgh radius now i want to configure in suchway that if radius server is down atleast I should be in the postion to login into the VPN box from my VPN client s/w trgh local UID and access my network(local ID should not be adminstretive purpose, it shld be access the local network how we are accessing the LAN trgh radius).
Thanks in advance.
sateesh
08-04-2009 06:51 PM
create a backup tunnel group that uses local authentication. or setup a second radius server.
08-04-2009 07:46 PM
I appreciate your quick response.
create a backup tunnel group that uses local authentication..
we need one more VPN concentrator for backup tunnel?
sateesh kumar.k
08-04-2009 08:12 PM
no..use same concentrator. create another group.
08-04-2009 11:53 PM
Give me some steps how make the other grp it as a bckup tunnel grp.
Sateesh
