Contexts with Active-Active configuration
Aug 4th, 2009
Having read the Active-Active configuration for context's it is still not clear to me. Here is what I understood please correct if I am wrong.
I have four different contexts and one admin context.
1. If I configure ASA - Unit-1 as an active device for context_1 and context_2. Obviously ASA Unit-2 is failover device for context_1 and context_2.
2. Next, I will configure ASA Unit-1 as a failover device for context_3 and context_4. Obviously ASA Unit-2 will be active for Coontext_3 and context_4.
3. So when, all is well tarffic for Context_1 and context_2 will be forwarded by Unit-1 and traffic for context_3 and context_4 will be forwarded by Unit-2.
4. When one unit fails due to some reason, second unit will be only device forwarding traffic for all the four contexts.
Please correct if I am wrong.
Share the experience.
Thanks in advance
subodh
Overall Rating: 5 (1 ratings)
Jon Marshall Wed, 08/05/2009 - 03:13
Subodh
Correct. Active/active still uses the concept of active/standby per context or more specifically per failover group.
So lets say you have 4 contexts + admin.
Contexts 1 & 2 are mapped to failover group 1 as is the admin context.
Contexts 3 & 4 are mapped to failover group 2.
ASA1 is active for failover group 1
ASA2 is active for failover group 2
In normal operation traffic for contexts 1,2 + admin will use ASA1 as active firewall and traffic for contexts 3 & 4 will use ASA2 as active.
If ASA1 failed then all traffic would now use ASA2.
Jon
