RTR configuration pushed via snmp lost after reboot
Aug 5th, 2009
in the lab we test rtr function on cisco routers. We configure and manage rtr tests with our network management system Spectrum. Spectrum sends the tests via snmp to the routers. On the router you can see the tests with the "show rtr configuration" command:
SA Agent, Infrastructure Engine-II
Entry number: 158
Owner: name
Tag: tag
Type of operation to perform: dns
Target address: 10.1.1.1
Source address: 0.0.0.0
Source port: 0
Operation timeout (milliseconds): 5000
Operation frequency (seconds): 300
Next Scheduled Start Time: Start Time already passed
Life (seconds): Forever
Entry Ageout (seconds): 3600
Status of entry (SNMP RowStatus): Active
Connection loss reaction enabled: No
Timeout reaction enabled: No
Verify error enabled: No
Threshold reaction type: Never
Threshold (milliseconds): 5000
Threshold Falling (milliseconds): 3000
Threshold Count: 5
Threshold Count2: 5
Reaction Type: None
Number of statistic hours kept: 2
Number of statistic distribution buckets kept: 1
Statistic distribution interval (milliseconds): 20
Number of history Lives kept: 0
Number of history Buckets kept: 15
History Filter Type: None
This tests work fine until the router is reloaded. After reload all configured tests are lost.
Does anybody know if this is expected behaviour or if it's possible to store the rtr configuration automatically in nvram?
Many thanks,
Thorsten
Overall Rating: 1 (1 ratings)
glen.grant Wed, 08/05/2009 - 06:04
  • Purple, 4500 points or more
i would think the tool would have to have a way to do a "write mem " or copy run start" so that it gets stored in nvram , sounds like this is not being done.
thorsten.steffen Wed, 08/05/2009 - 06:26
Also when I do a write mem after the rtr config was send via snmp to the cisco there is no rtr config in the "show run".
So if there is any nvram space used for the rtr config then it's not the normal configuration space.
iyde Thu, 08/06/2009 - 12:17
  • Silver, 250 points or more
Initially (or was it a bug in some IOS versions - I do not remember at the moment) the rtr config was lost after reboot.
I used to work at a company where we were doing a lot of SLA measurement and we had to put procedures, or rather scripts, in place to ensure that if a router got reloaded the SLA config was pushed out again.
I believe that you are using semi-old IOS, 'cause the command syntax nowadays is "ip sla ..."
