IPMA
Aug 5th, 2009
Hi experts,
I had configured IPMA, everythings look good, but I am facing to issues:
1- the 7965 did not support the IPMA when I use the service to access the assistant.
2- the 7975 work as manger but the icons appear without color.
I have CM4.1 SR5 and i had upgrade the firmware for the phones to the lates one.
Jaime Valencia Wed, 08/05/2009 - 09:30
I would assume you read the config guide which states which phones support IPMA, 7965 is not one of them
As you do not mention if this is proxy or shared line if this is not your config click on the right link from the doc
System Requirements for Cisco IPMA with Proxy Line Support
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/4_1_3/ccmfeat/fsipma.html#wp1071355
java
if this helps, please rate
