WLC-Radius Integration..
Aug 5th, 2009
I want to do the WLC authentication with radius.the problem is when i enter the username and password , in radius it shows authentication passed but in telnet prompt it asks again for username password as if wrong username-password.
attached are debug capture of WLC and radius config summry.
can u please help me on the same
sameermunj Wed, 08/05/2009 - 21:42
similar incident i have observed on cisco.
Problem Title
Unable to login to WLC even after the successful authentication message is received from the RADIUS Server
Resolution For the Remote Access Dial-In User Service (RADIUS) user to login to the controller, the login user entry in the RADIUS server has to be associated with an attribute, Service-Type.If this attribute is not sent back to the controller from the ACS, the authentication finishes successfully (access-accept) and you do not see any authorization error on the controller, even with debug aaa all enable. But, you are prompted again for authentication. The only thing missing in the RADIUS return packet is the service type 6 attribute.Refer to the Before Using RADIUS Attributes section of RADIUS Attributes for more information on how to configure the service-type attribute.
It seemseverything ok in WLC and radius attribute is a problem..
