AAA Radius Authentication for Calling Card Platform
Aug 5th, 2009
I am using AS5350 and I am using it for calling card application using Clear Box as my RADIUS Server for AAA. My question now, how would I know if cisco is sending the dtmf for "enter card number.au" on the RADIUS server ? Does the card number included on the VSA ? below are my configurations and the debug info. The problem here is that the card number that I entered doesn't able to match against the configuration on my Clear Box/SQL Database. I want to know what should I expect from CiscoAS5350 to send a vsa for enter_card_number ?
aaa new-model
aaa group server radius ClearBox
server 192.168.1.1 auth-port 1812 acct-port 1813
aaa authentication login default local
aaa authentication login h323 group ClearBox
aaa authorization exec h323 group ClearBox
aaa accounting exec default start-stop group ClearBox
aaa accounting network default start-stop group ClearBox
aaa accounting connection h323 start-stop group ClearBox
aaa session-id unique
radius-server host 192.168.1.1 auth-port 1812 acct-port 1813
radius-server key 7 0355481F031F761D
radius-server vsa send accounting
radius-server vsa send authentication
call application voice prepaid tftp://192.168.1.2/debitcard-multi-lang-Cisco.1.1.0.2.tcl
call application voice prepaid pin-len 10
call application voice prepaid warning-time 300
call application voice prepaid redirect-number 8662195822
call application voice prepaid language 1 en
call application voice prepaid language 2 sp
call application voice prepaid language 3 ch
call application voice prepaid set-location en 0 tftp://192.168.1.2/prompts/
call application voice prepaid set-location sp 0 tftp://192.168.1.2/prompts/
call application voice prepaid set-location ch 0 tftp://192.168.1.2/prompts/
gw-accounting aaa
Getting session id for NET(00003600) : db=6418E654
AA/ACCT/NET(00003600): add, count 1
Getting session id for NET(00003601) : db=6410D098
AAA/ACCT/NET(00003601): add, count 1
AAA/ACCT/CONN(00003601): Pick method list 'h323'
AAA/ACCT/SETMLIST(00003601): Handle 94000002, mlist 62D3B124, Name h323
Getting session id for CONN(00003601) : db=6410D098
AAA/ACCT/CONN(00003601): Queueing record is START
AAA/ACCT(00003601): Accouting method=ClearBox (RADIUS)
AAA/ACCT/EVENT/(00003601): ATTR ADD
AAA/ACCT/CONN(00003601): START protocol reply PASS
AAA/ACCT/EVENT/(00003601): VOICE DOWN
AAA/ACCT/HC(00003601): Update VOICE/000020D3
AAA/ACCT/HC(00003601): VOICE/000020D3 [sess] (rx/tx) base 0/0 pre 0/0 call 0/0
AAA/ACCT/HC(00003601): VOICE/000020D3 [sess] (rx/tx) adjusted, pre 0/0 call 0/0
AAA/ACCT/CONN(00003601): Queueing record is STOP osr 1
AAA/ACCT(00003601): del node, session 174133
AAA/ACCT/CONN(00003601): free_rec, count 1
AAA/ACCT/CONN(00003601): Setting session id 174144 : db=6410D098
AAA/ACCT/HC(00003601): Deregister VOICE/000020D3
AAA/ACCT/EVENT/(00003601): CALL STOP
AAA/ACCT/CALL STOP(00003601): Sending stop requests
AAA/ACCT(00003601): Send all stops
AAA/ACCT/NET(00003601): STOP
AAA/ACCT/NET(00003601): Method list not found
AAA/ACCT/CONN(00003601): STOP protocol reply PASS
AAA/ACCT/CONN(00003601) Record not present
vmoopeung Tue, 08/11/2009 - 14:25
VSAs are collected by the RADIUS server during the accounting process when AAA is configured with the Debit Card feature. Data items are collected for each call leg created on the gateway. A call leg is the internal representation of a connection on the gateway. Each call made through the gateway consists of two call legs: incoming and outgoing. The call leg information emitted by the gateways can be correlated by the connection ID, which is the same for all call legs of a connection.
Use the H.323 VSA method of accounting when configuring the AAA application.
There are two modes:
•Overloaded Session-ID
Use the gw-accounting h323 syslog command to configure this mode.
•VSA
Use the gw-accounting h323 vsa command to configure this mode.
