Could not Collect RME
Aug 5th, 2009
Dear all,
i m getting the following error, how can i rectify this
TELNET: Failed to establish TELNET connection to 192.168.209.44 - Cause: Authentication failed on device 3 times. VLAN Config fetch is not supported using TFTP.Could not detect protocols running on the device VLAN Config fetch is not supported using RCP.
Rajiv Dasmohapatra Wed, 08/05/2009 - 05:17
chk whether u are able to login to device from ciscoworks and also check whether u are able to do so using the username provided to CW. disable RCP and tftp. SSH and telnet is enough for all.
luijimen Wed, 08/05/2009 - 15:06
  • Cisco Employee,
Hi.
The error means that the Primary Credentials (cli credentials) specified for this specific device are incorrect.
Manually telnet to the device and take note of the username/password/enable password you use to reach ENABLE mode.
Then, specify these values under Primary Credentials in Common Services > Device and Credentials > Device Management.
Make sure to select your affected device and click "Edit Credentials".
networking11 Thu, 08/06/2009 - 02:35
one main thing i forget to say is , i m adding the same devices int ACS 4.2& giving different user names for different groups,
Could i have to give the /local user of the Device or Remote user like given for Lms Server (ie rcp user)
ilnaiduccna Thu, 08/06/2009 - 05:39
You can use any user which able to login the device.
Make sure you are give right username, password and SNMP string.
Naidu.
