Unity Connection Failover (HA) testing
Aug 5th, 2009
I can't see to find any documents testing the High Availability and user experience of a failover, i.e. expected recovery times, outage during a call etc.
Is there anything available?...cheers, Jag
Overall Rating: 4 (1 ratings)
Rob Huffman Wed, 08/05/2009 - 05:50
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Jag,
Check out the following to see the expected behaviours during Failover etc.;
About a Cisco Unity Connection Cluster
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/cluster_administration/guide/7xcuccag020.html
Active Active Redundancy - Check out the Power point slides and Video
http://www.ciscounitytools.com/TOI_CUC701.htm
Hope this helps!
Rob
jeff.singh_2 Wed, 08/05/2009 - 07:30
hey Rob,
thanks - had seen those docs before, just forgot about them :-((
Still getting issues when failing the primary server, if the secondary fails it works fine but during primary failure we just can't login to the system.
