t.37 file attachment...
Aug 5th, 2009
Hi to all,
the t.37 protocol on cisco devices work only using tiff or giff as attachment? Isn't possible to use doc, pdf or other type of files? Someone know of a software capable of convert anything in gif or tiff? For me isn't a problem but for the common user seems a big problem to save files in other format!
T.37 is very useful, in one piece of metal you can manage all the comunications without external fax server or other stuff.
I can use fax detection with on_ramp and off_ramp tcl scripts? Or it can be a problem?
Thanks and best regards,
Carlo S.
