IPsec VPN issue
PWCSinfosec
I am having an issue with a windows vista ultimate laptop (32bit). I have the
vpn client version 5.0.03.0560 installed and using ipsec. The client successfully
connects and is authenticated. It gets an internal IP address from the vpn ip pool. When
using a verizon wireless aircard the client CAN communicate with internal systems, email,
file share, internal websites, etc. However, when it connects using an external
connection (onboard wireless NIC and wired NIC), home network, starbucks, etc the vpn client connects
successfully, gets an ip address from the pool, however, there is NO connectivity to
internal systems.
I took this same vpn profile .pcf and installed the same version of the vpn client on
another vista ultimate laptop and it worked fine.
The problem laptop has trend micro officescan for its virus protection/firewall and the windows
firewall is disabled. The laptop that worked correctly has the exact same set up and
versions.
Has anyone run across this issue, it is an issue with the laptop, however I can figure out
what is causing the problem with the network connectivity.
sziaulla
When you connect through home network etc you are behind the NATing device. You need to have NAT-T (NAT traversal) enabled on the head end.
Also, once your connection gets established do you see encap counter incrementing on the vpn client statistic section?
thanks
-Syed
