Will CiscoWorks IPM 2.6 Run on Solaris 10?
Aug 5th, 2009
All,
The install docs for CiscoWorks IPM 2.6 states that it will run on Solaris 8 or 9.
Does anyone know if it will run on Solaris 10?
Stephanie
Overall Rating: 5 (1 ratings)
Lucien Avramov Wed, 08/05/2009 - 09:56
  • Red, 2250 points or more
I have not tried since we dont support it.
A couple of things, hardware, drivers may be different, the java version as well.
It may install or you may have issues, I'm not sure. I recommend you to avoid that scenario as engineering did not test it.
Joe Clarke Wed, 08/05/2009 - 10:07
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
It will absolutely not work. The database engine will not function on Solaris 10.
Lucien Avramov Wed, 08/05/2009 - 08:49
You have to stick to the release notes for TAC support, for that reason I do not recommend you to install it on solaris 10.
