08-05-2009 08:17 AM - edited 03-15-2019 07:14 PM
We are running CCM 6.1.3. All our phones are Cisco Phones running in SCCP mode.
We are planning to roll out extension mobility to all our employees very soon.
Our management would like us to try third party SIP phones in the future since they are cheaper.
I would like to know if third party sip phones support extension mobility.
Thanks in advance for your help.
Solved! Go to Solution.
08-05-2009 08:43 AM
That would be a big no.
08-05-2009 08:59 AM
The list i provided already shows which phones provide support for EM with SIP
If a phone is not there, then it's not supported
java
if this helps, please rate
08-05-2009 08:36 AM
SIP Support for Cisco Extension Mobility
Cisco Extension Mobility supports the following Cisco Unified IP Phones that are running SIP:
â¢7970G/7971G
â¢7961G/7941G and 7961GE/7941GE (G = Non Gig; GE = Gig)
â¢7942G, 7962G, 7945G, 7965G, and 7975G
â¢7911G
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/6_1_1/ccmfeat/fsem.html#wp1272341
java
08-05-2009 08:41 AM
Hi Java,
How about third party (non-cisco) SIP phones? Can they support extension mobility and other IP phone services?
Thanks a lot for your reply.
Cheers,
Bala.
08-05-2009 08:43 AM
08-05-2009 08:59 AM
java
08-06-2009 12:07 AM
Hi Java,
Tx a lot for your help!!!
The answer will definitely guide our choice of phones in the future!!!
Cheers,
Bala.
08-06-2009 12:10 AM
Hi Jon,
Tx you very much for the reply.
Your reply has put a full stop to the discussion of third party phones in our organization. ;-)
Cheers,
Bala.
