PRI line signaling
TY08
Guys,
Does anybody have experience with SL-1 signaling type? My provider can only support SL-1, do you think it's going to comptabile with UC 520? Normally, the ISDN switch type is NI2 or NI.
Anyone has sample output?
Thank you
Are you using CCA do this this?  You should be able to select the ISDN switch type there to be DMS100.
If not, the command is...
isdn switchtype primary-dms100
Steven Smith
Level 7
Level 7
I believe this should work if you have the switch type as DMS100.  SL-1 is a nortel protocol.
so, this should work fine with UC520, right. Yes, SL-1 is a nortel protocol.
I am not sure what is the comptatible command line for ISDN switch type.
