cann't access to router through SSH
Aug 5th, 2009
Here is the config:
hostname 2801CCME
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
memory-size iomem 5
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
username user password 0 cisco
username test privilege 15 password 0 cisco
username bob password 0 cisco
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp policy 2
crypto isakmp key cisco address 10.2.1.2
crypto isakmp key cisco address 10.10.3.2
crypto ipsec transform-set my_tranform_set esp-3des esp-sha-hmac
crypto ipsec transform-set my_transform2 esp-3des esp-sha-hmac
crypto ipsec transform-set my_transform3 esp-3des esp-sha-hmac
crypto map SDM_CMAP_1 1 ipsec-isakmp
description Tunnel to10.10.3.2
set peer 10.10.3.2
set transform-set my_transform3
match address 102
interface FastEthernet0/0
description $FW_INSIDE$
ip address 10.10.2.1 255.255.255.0
duplex auto
speed auto
interface Serial0/0
ip address 10.10.3.1 255.255.255.0
clock rate 64000
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
clock rate 2000000
ip forward-protocol nd
ip http server
no ip http secure-server
access-list 100 remark SDM_ACL Category=4
access-list 100 remark IPSec Rule
access-list 100 permit ip 10.10.2.0 0.0.0.255 10.2.1.0 0.0.0.255
access-list 101 remark SDM_ACL Category=4
access-list 101 remark IPSec Rule
access-list 101 permit ip 10.10.10.0 0.0.0.255 10.10.3.0 0.0.0.255
access-list 102 remark SDM_ACL Category=4
access-list 102 remark IPSec Rule
access-list 102 permit ip 10.10.2.0 0.0.0.255 10.10.3.0 0.0.0.255
no cdp run
tacacs-server host 10.10.2.2
tacacs-server key CCNP
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
login local
transport input ssh
end
WHat is wrong here?
Overall Rating: 4 (1 ratings)
Richard Burts Wed, 08/05/2009 - 11:05
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Alexandr
Given what is in the config that you posted I would guess that the most likely issue is whether you have generated RSA encryption keys which are required for SSH to work. Did you generate RSA encryption keys?
Rick
webstd.design Wed, 08/05/2009 - 11:10
What i did
2801CCME(config)#ip domain-name cisco.com
2801CCME(config)#crypto key generate rsa
The name for the keys will be: 2801CCME.cisco.com
Choose the size of the key modulus in the range of 360 to 2048 for your
General Purpose Keys. Choosing a key modulus greater than 512 may take
a few minutes.
How many bits in the modulus [512]:
% Generating 512 bit RSA keys, keys will be non-exportable...[OK]
2801CCME(config)#
*Mar 1 01:04:30.083: %SSH-5-ENABLED: SSH 1.99 has been enabled
webstd.design Wed, 08/05/2009 - 11:11
As I understood I couldn't access to router though SSH without had ip domain-name command configured. Am I right?
Richard Burts Wed, 08/05/2009 - 11:16
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Alexandr
As I understand it: having a domain name configured is required to be able to generate the RSA keys. And having RSA keys generated is required to access the router through SSH. So indirectly it is correct that you can not access the router via SSH without a domain name configured.
Rick
vcjones Thu, 08/06/2009 - 09:18
  • Silver, 250 points or more
My experience to date: You need a hostname and a domain name configured in order to generate RSA keys. Once you generate the RSA keys, you need to "copy run start" to keep them over a reboot. Once they are saved, you can change/delete hostname and domain name to your hearts content. Some of this behavior is probably IOS release or platform specific, so YMMV.
Vince
Richard Burts Thu, 08/06/2009 - 10:22
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
My experience is different from Vince. I am not sure that copy run start is needed - though it certainly does not hurt. And in my experience if you change the host name then it invalidates the RSA keys and you need to re-generate the RSA keys.
Rick
vcjones Thu, 08/06/2009 - 13:13
As I said in my original response, your mileage may vary. On the last systems I tested (1811s running 12.4(15)XY5) changing the hostname in the config had no impact on ssh accessibility while failure to save the first key generated with a "copy run start" did. I recall working on other devices which had a separate command to save the keys. Whether or not it should is a separate issue, as anyone who deals with routers knows. (In theory there is no difference between theory and practice, however, in practice, there is.)
Vince
