Connection 7x - HA Sub can't fine Pub
Aug 5th, 2009
Greetings,
I am going through the install of the secondary server in a Connecion 7.1(2) Cluster. When I get to the part where it asks for the hostname, IP and security password of the publisher it kicks back an error saying it cannot communicate with the Pub, make sure it is powered on.
I can ping both servers, I can ssh to both servers. I can ping the the sub from the pub. I have gone as far as putting a cheap linksys switch between the two and still no joy.
I did verify the the NTP is properly synced. I reset the the SP on the pub and rebooted. I have configured the secondary server in the cluster per the document. There has to be something simple I am missing, but no clue what it might be.
Any help is appreciated.
Ginger Dillon Wed, 08/05/2009 - 12:42
Hi -
On your Publisher cuadmin, go to System Settings - Cluster. Click Add New. Add the following information for the Subscriber - IP address, MAC address, and Description of your cluster. Resave the information if already there. Do both servers show up in this screen? Do both servers show up when you check this same area on your Subscriber?
Ginger
Ginger Dillon Wed, 08/05/2009 - 12:55
Hi - Here is a link to the cluster troubleshooting guide - http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/troubleshooting/guide/7xcuctsg080.html#wp1052957
Another thing I would check is in Serviceability - Service Management - On the Control Center - Feature Services page, under Status Only Services, confirm that the Connection Server Role Manager service has the Started service status.
Ginger
ahochau_2 Wed, 08/05/2009 - 13:06
The servers had to be re-ordered with the 146GB drives inorder to support High Availability. Since the servers were spec'd by Cisco I am going under the assumption they support HA. There are only 2 servers and it is not BE. The service is started.
ahochau_2 Fri, 08/07/2009 - 12:12
Eventually the fix was doing the install until it was successful. the only thing different about the last attemp was I only uploaded the license file for the primary server. Once the secondary was up, I loaded the license file for that one. Not sure what happened, but pretty sure I don't like it.
