ivillegas Tue, 08/11/2009 - 14:17
  • Silver, 250 points or more
Are there any Firewalls between the agents, supervisor or CRS server? If yes disable it.
mohamed-gheta Wed, 08/12/2009 - 05:07
If this is Enterprise then check that you added the distributer DB to CCM PG in PG explorer
Also from the same window make sure that the DB is enabled
