CSS SSL Multiple Applications
Aug 5th, 2009
Is it possible to do the following on CSS with SSL module:
content ssl-rule
vip address 10.10.10.1
protocol tcp
port 443
add service ssl_module1
application ssl
advanced-balance ssl
active
content rule-1
vip 10.10.10.1
port 80
add service service1
add service service2
active
content rule-2
vip 10.10.10.1
port 8080
active
content rule-3
vip 10.10.10.1
port 8081
active
Basically the VIP is same but port numbers differ.
jason.espino Thu, 08/06/2009 - 16:18
The configuration you have outlined is fine. You can have multiple content rules with the same VIP address balance upon different inbound ports. However, what VIP/port within the proxy-list do you want the CSS to send the decrypted SSL traffic to?
10.10.10.1:80
10.10.10.1:8080
10.10.10.1:8081
What are you trying to accomplish?
Gilles Dufour Fri, 08/07/2009 - 01:26
That's exactly how you have to do it.
Use different rules with the same virtual ip but different port.
You can also have the same port ip, same port but different "url" command so depending on the url requested by the user you performance different type of loadbalancing or send a redirect ...
Gilles.
