RADIUS Authentication @ FAILED
Aug 5th, 2009
Hello Everybody
I have a ACS Appliance running version 4.2 ==> ACS where the function is just for authenticate users by
protocol RADIUS against a Active Directory - Microsoft.
The Remote Agents are running, AAA Clients and Server are OK and the External User Database (AD TREE) are mapped.
When starting a authentication it doesn't work and in the FAILED ATTEMPS ACTIVE, the AUTHENTICATION CODE FAILURE is " INTERNAL ERROR "
Which tests can i perform ?
I doesn't found good documentations about " INTERNAL ERROR "
darpotter Mon, 08/10/2009 - 04:12
Any time you "internal error" it means ACS has tripped over itself. Generally this is either a bug (possibly already fixed) or an unexpected error condition arising from a mis-config.
You'll need to speak to the TAC
