Packet drop
Aug 5th, 2009
Is there a way a SNMP trap can be generated with a packet drop on an interface.
Can RMON handle a packet drop notification. Also, is there any syslog message which is generated for this.
Overall Rating: 5 (3 ratings)
Lucien Avramov Wed, 08/05/2009 - 17:20
  • Red, 2250 points or more
Check to see if your device support this old mib, that would be way to get the queue drops:
From OLD-CISCO-INTERFACES-MIB
locIfInputQueueDrops = .1.3.6.1.4.1.9.2.2.1.1.26
locIfOutputQueueDrops = .1.3.6.1.4.1.9.2.2.1.1.27
If those OID are on your router, then as you said, you can try to use rmon with it.
example:
mon alarm 1 1.3.6.1.4.1.9.2.2.1.1.26.2 1 absolute rising-threshold 1 falling-threshold 1 1
Then you use an rmon event to trigger the trap, as per the standard configuration guide:
http://www.cisco.com/en/US/partner/tech/tk648/tk362/tk560/tsd_technology_support_sub-protocol_home.html
Now, you have to add the interface index to it at the end :1.3.6.1.4.1.9.2.2.1.1.26.X where X is the interface index, you can get that by doing an snmpwalk on ifname to match it.
Joe Clarke Wed, 08/05/2009 - 18:02
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This example won't yield desired results. The queue drop objects are counters, and an absolute counter value doesn't tell you much. You would want to use delta.
However, I mush prefer the EEM approach. EEM allows you to watch interface drops without needing to know the ifIndex. For example, to watch interface drops on FastEthernet0/0:
event manager applet interface-drops
event interface name FastEthernet0/0 parameter input_packets_dropped entry-op ge entry-val 1 entry-type increment exit-op lt exit-val 1 exit-type increment poll-interval 60
action 1.0 snmp-trap strdata "Interface $_interface_name saw $_interface_delta_value $_interface_parameter over the last 60 seconds"
This particular example assumes a recent version of IOS, but the entry-type and exit-type parameters can be changed to entry-val-is-increment true and exit-val-is-increment true for earlier versions of IOS.
georgeef1 Thu, 08/06/2009 - 12:50
Hi jclarke,
Thank you so much for the information.
Even after all this, my question is can it be handled by a syslog or a SNMP trap so I get the notification after a packet drop.
Joe Clarke Thu, 08/06/2009 - 12:55
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
My EEM example will send an SNMP trap. If you need a syslog, you can add:
action 2.0 syslog msg "Interface $_interface_name saw $_interface_delta_value $_interface_parameter over the last 60 seconds"
georgeef1 Mon, 08/10/2009 - 09:36
Hi Jclarke,
Thanks for this wonderful suggestion.
But, unfortunately, I guess EEM will not work for us because our standard IOS is 12.2(18) SXF9. So any other solutions/suggestions you can send my way are greatly appreciated.
Thanks a lot.
Joe Clarke Mon, 08/10/2009 - 09:41
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
EEM will work in IOS 12.2(18)SXF9. The applet I provided you will work fine. You will just need to use the older "entry-val-is-increment" notation.
georgeef1 Mon, 08/10/2009 - 17:08
Hi Jclarke,
Thankd for all your help.
Can you please clarify the syntax for me with this one?
Is this correct for our IOS?
entry-val-is-increment true exit-val-is-increment true poll-interval 60
Thank you.
Joe Clarke Mon, 08/10/2009 - 20:07
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The syntax would be:
event interface name FastEthernet0/0 parameter input_packets_dropped entry-val 1 entry-op ge entry-val-is-increment true exit-val 1 exit-op lt exit-val-is-increment true poll-interval 60
georgeef1 Thu, 08/13/2009 - 13:59
Hi Jclarke,
Thanks for all the wonderful information.
As per the EEM you told me a script for the interface. is there a way we can configure EEM on global config to have it applied on all the interfaces automatically.
Joe Clarke Thu, 08/13/2009 - 14:10
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Unfortunately, no. However, if you wanted to convert the applet policy to a Tcl policy, you could run a script periodically to check all interfaces for errors. With your version of IOS, in order to keep using applets, you'd have to add one applet per interface.
georgeef1 Thu, 08/20/2009 - 07:07
I went to apply this for multiple interfaces and the last entry overwrites the previous entry. So my question is, do I need to create a new event manager applet interface-drops for each interface I want to monitor?
Joe Clarke Thu, 08/20/2009 - 07:10
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You will need to use unique names for your applets. For example:
interface-drops-fa1/1
interface-drops-fa1/2
