Reason 429: Unable to resolve server address. Help!!!!
Aug 5th, 2009
I have a cisco ASA5520 using Client 5.05. I currently am using the public ip address under the hostname and everything works fine. I created a dns name with my isp and let it populate and it does not work. It does not even hit the asa. I checked on dnsstuff and the ip resolves to the name.Does anyone have any idea on how to resolve this?
Roman Rodichev Wed, 08/05/2009 - 17:56
  • Gold, 750 points or more
If you ping the hostname from the same PC that Client is installed on, does it resolve?
kmcilvaine Wed, 08/05/2009 - 18:04
It does not resolve, which led me to believe a dns problem but when i checked on dns stuff it is correct.
Roman Rodichev Wed, 08/05/2009 - 19:45
Your client must be able to resolve it if you want to use it for VPN connection.
kmcilvaine Thu, 08/06/2009 - 05:33
So if i am correct this has nothing to do with the client or the asa....this is a dns issue correct
