Black pages in System admin
Aug 5th, 2009
Hi Guys i geting blank pages in the system admin when looking at subscribers profile/callhandlers.
The page source shows this at the bottom of the page
<font face="Arial" size=2>
<p>Microsoft VBScript runtime </font> <font face="Arial" size=2>error '800a01ad'</font>
<p>
<font face="Arial" size=2>ActiveX component can't create object: 'AvMiuAdm.AvMiuAdmScript.1'</font>
<p>
<font face="Arial" size=2>/Web/Common/include/SaIntegrationsInc.asp</font><font face="Arial" size=2>, line 20</font>
the version is 5.01
Any help would be great
Tray Stoutmeyer Mon, 08/10/2009 - 20:54
  • Cisco Employee,
This matches a few things but lets start with trying this....
To resolve this issue, you must update Component Services with the new password. Do the following procedure:
Step 1 On the Cisco Unity server, on the Windows Start menu, click Programs > Administrative Tools > Component Services.
Step 2 In the right pane, expand Component Services > Computers > My Computer > COM+ Applications.
Step 3 Right-click Cisco Unity and click Properties.
Step 4 Click the Identity tab.
Step 5 Enter and confirm the new password.
Step 6 Click OK to save the changes, then close the Component Services window.
Step 7 If the Cisco Unity Administrator is open, close it.
For step 5, just put the proper password that currently exists for the current service account listed (I think it's UnityMsgStoreSvc).
Let me know if this resolves it. If so, it's bug CSCsl17919. If not, there are some other things we can try.
Tray
tonygray Mon, 08/10/2009 - 20:56
Thanks for your reply .
I searched and found that bug earlier and have tried it to no avail :(
Tray Stoutmeyer Mon, 08/10/2009 - 21:02
  • Cisco Employee,
How about just registering the dll??
This is a component which resides in a DLL file. To discover where,
please do the following:
1. Start>Run>dcomcnfg
2. Drill down to the AvMiuAdm.AvMiuAdmScript.1 object to see if it exists
3. If it does, go to the directory with the .dll that I have highlighted
and type the following at a command prompt:
regsvr32 x:\CommServer\Components\AvMiuAdmSvr.dll and you should see a
prompt saying it registered successfully
4. Then try accessing Alternate Extensions page in SA again and let me
know the results
5. If the above doesn't resolve this issue; right click on the
AvMiuAdm.AvMiuAdmScript.1 object, disable it, attempt to view alternate
extensions page in SA, enable the object, then attempt to access
alternate extensions page in SA again.
See what you get on that. Also try restarting the www service in the services snap in.
Tray
