Call Forwarding Doesn't work properly
Aug 5th, 2009
I have CCM 6.1.2..Whenever i do "Call-Forward" from an IP Phone it works as per my requirement like if the user has LANDLINE calling privilege, then he/she can forwards it to the landline....
But the problem i am facing is: after a period of time (nearly 40-45 minutes) i find the Call Forwarding Option in the IP phone goes disabled & the phone display shows normal...then again i can forward the call......can someone help me in this!!
Overall Rating: 1 (1 ratings)
smalkeric Tue, 08/11/2009 - 14:05
  • Silver, 250 points or more
It may be a problem with the micorsoft exchange. You may try using Enhanced iDivert to divert the call directly across the SIP Trunk to voicemail so the Remote-party-ID is in the original INVITE and this seems to be working.
